Large template uploads: output cut off at ~270 KB, and nightly segfaults since build 4287 **solved**
Posted: Mon Aug 24, 2026 6:54 am
I stumbled over something while uploading files with the "template:filename" mechanism and thought I'd mention it, in case it's
useful to you. No urgency — I found a way around it.
Setup: Meteobridge 6.4 on a Raspberry Pi 4 Model B Rev 1.1 (originally build 4267, now on 4297 via auto-update). A nightly
script on the device writes some JSON text files, and scheduled events
upload them via SFTP as templates.
What I see: Smaller files (up to ~200 KB) arrive on the server just fine. But one file grew over time to about 290 KB, and that one arrives
incomplete: the end is missing, and near the point where it gets cut off there is a strange bit of text in the middle of the data that reads
So it seems there is a maximum size for template files somewhere around 270 KB? I couldn't find anything about it in the wiki — maybe I just
missed it.
My workaround: I now split the export into two smaller files and upload them with two events — works perfectly, so I'm all set. And I
could imagine the limit is simply there so that the smaller platforms can keep up, which would make perfect sense.
Just wanted to let you know, since the cut-off file looks a bit confusing at first. Happy to send you a sample file if that helps.
Update Aug 23: One more observation that may be related. My box updated itself to 6.4 build 4287 (Aug 21 2026), and last night the data
logger crashed repeatedly — but only during the two minutes when my two larger template uploads (~150 KB and ~185 KB) were being processed. The
uploads themselves arrived complete and valid, and outside those windows everything runs fine. The log shows for each crash:
and once a variant ending in
any crash, so this might be new in 4287.
Second night (Aug 24): it reproduces exactly, and got worse — by now the box had auto-updated itself again to build 4297 (Aug 23 2026),
and on that build I got 15 crashes in three bursts, each starting precisely at one of the three upload slots (00:30, 00:45, 01:00;
template sizes ~160/150/185 KB). So builds 4287 and 4297 both show it, while 4267 ran the same events for days without any crash. More
trace variants appeared, all pointing into template/sensor processing:
The uploads still arrive complete and valid every
time, but each crash/restart cycle now costs about a minute of per-minute logging (the affected day recorded ~1390 instead of ~1420
minute rows). Happy to provide full log excerpts or remote access if
that helps.
Thanks for the support
BR,
Marco
. This happens every night in the same way; as soon as I keep the file smaller, everything is fine again.cond_template_buf <
missed it.
child process received termination signal (11) in functions:
termination_handler < get_wssensor_temp10 < get_wssensor < get_set <
get_set_long < get_set < get_set_long < ... (repeats)
. After each crash the logger restarts by itself (with the usual... send_wnet_nosensor < test_inetupload
message) and recovers; the nightly backup afterwards completed normally. On build 4267 the same events ran for days withoutbind (port 22222)
andskipn < print_wind_sensor* < get_set < get_set_long < ...
.setup_pipe < get_sensorid < print_num_sensor < sensor_copy < get_wssensor < ...
that helps.
BR,
Marco
