Ability to change Time and Date Formats
The ability to set the time and data formats would be great as the carry over to WD Live and we're a little different in the US... Thanks! :cheer:
Re:Ability to change Time and Date Formats
Oh yeah - continue the great WD Live support - it's the main reason I purchased the Meteohub - Great Work!!!! :cheer:
If you're feeling brave, you should be able to edit the clientraw template files to change how the time/date is sent to WD-Live.
See this thread for the location of the clientraw*.conf files (/home/meteohub, which you will need to ssh or FTP in to access), and then read section 3.4 of the most recent manual for how to parse out substrings from longer strings in the HTML template tags.
The only question then being, will WD-Live recognize your modified date/time string? It might need the data in a specific format (see some of the previous threads about known bugs in the WD-Live implementation), and then changes to its configuration to adjust how the final display is shown.
