Calibrations relative to WL Cloud?
Calibration Offset/Factor as applied under Stations/Settings/Calibration can be confirmed in the Live Data Tab as well as (at least) Weather Nets like Wow-BE , Wow-UK etc.
I don't see calibrations included in uploads to WL Cloud? Would this be correct?
ClimateBlender
Re: Calibrations relative to WL Cloud?
Post by ClimateBlender »
For this comparison, is WL Cloud being fed by Meteobridge's Weather Nets upload, or by a separate Davis logger/console connection? A calibration applied only inside Meteobridge would not change an independent upload that bypasses it.
For the Meteobridge route, which sensor and which WeatherLink display are you comparing: a current reading or an archived interval? The wiki says calibration affects data from the point it is saved and does not alter already logged readings:
https://www.meteobridge.com/wiki/index. ... alibration
I can't confirm from that page whether the WL Cloud uploader applies every calibration, so I wouldn't assume the WOW result proves that the WeatherLink path behaves identically.
WL Cloud, Wow-BE & Wow-UK (plus other comparative exports) all uploading from the same source, NanoSD in a Davis Envoy hence any calibration can be confirmed for all except WL Cloud which could be the case, just trying to confirm if in fact this is the case by function? Not comparing past logged readings, all being compared in the same instance. The focus here is on wind speed, wind0wind and wind0avgwind, one can exaggerate the calibration factor which clearly indicates/affects the output as expected, except WL Cloud?
