Hi all,
When I boot up my Meteobridge Pro2 (MB-Pro2) I can see in the logs that nbiot starts a provider scan that can take up to 60 minutes. After one hour it times out and "module reset failed". See log output below:
oled (26.11.2026 17:47:49): process started.
setup (27.11.2026 12:24:18): use UTC stamp 2026-11-27 12:24:18 (1 tries)
nbiot (27.11.2026 12:24:19): provider scan started, can take up to 60 minutes
dbase (27.11.2026 12:24:27): process started.
dbase (27.11.2026 12:24:29): Content of RAM database restored.
system (27.11.2026 12:24:30): start of internal sensor evaluation initiated.
wnetd (27.11.2026 12:24:31): process started.
wnetd (27.11.2026 12:24:31): send data thread started (pid:3028 tid:3029)
system (27.11.2026 12:24:31): start of logging process initiated.
logger (27.11.2026 12:24:31): databases connected. Update interval 3600 seconds.
logger (27.11.2026 12:24:31): data logger started.
logger (27.11.2026 12:24:36): connect station 0 (RF Vantage via serial).
logger (27.11.2026 12:24:36): connect station 9 (System Data via Plug-in).
logger (27.11.2026 12:24:39): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (27.11.2026 12:24:39): services paused.
logger (27.11.2026 12:24:45): station 0 (RF Vantage), transmitter 1 registered as ISS
logger (27.11.2026 12:24:45): station 0 (RF Vantage), initialization string sent to device /dev/ttyS0
logger (27.11.2026 12:24:45): station 0 (RF Vantage), MBPRO2RF Version 2.4
logger (27.11.2026 12:24:45): station 0 (RF Vantage), debug off
logger (27.11.2026 12:24:45): station 0 (RF Vantage), verbose off
logger (27.11.2026 12:24:45): station 0 (RF Vantage), output raw
logger (27.11.2026 12:24:45): station 0 (RF Vantage), output raw (10 bytes)
logger (27.11.2026 12:24:45): station 0 (RF Vantage), filter on
logger (27.11.2026 12:24:45): station 0 (RF Vantage), rx threshold set to -90db
logger (27.11.2026 12:24:45): station 0 (RF Vantage), listening to tx 1
logger (27.11.2026 12:24:45): station 0 (RF Vantage), bandwidth normal
logger (27.11.2026 12:24:45): station 0 (RF Vantage), frequency band 868MHz (EU)
dbase (27.11.2026 12:24:51): database sync done (48 tables, 97/2736 writes).
logger (27.11.2026 12:25:50): sensors are now providing data.
logger (27.11.2026 12:25:50): services started.
nbiot (27.11.2026 13:24:28): provider scan timed out
nbiot (27.11.2026 13:44:37): module reset failed
As far as I can tell my MB-Pro2 does not have NBIOT functionality and I do not need it. How can I switch off this behaviour?
Maybe related to this (not sure), my MB-Pro2 display stays on the boot logo with a completed progress bar (see attached photo). I assume something is not completing correctly. Data logging seems to work fine. Red LED light flashes irregularly, slowly, about 3-4 single flashes, the occasional double-flash.
Current configuration:
Platform: Meteobridge PRO2 * (32MB Flash)
RAM: 123 MB total, 47 MB free (61% used)
Storage: WD SLC, 14.7 GB total, 14.5 GB free (2% used, 30.1 yrs)
SW Version: Meteobridge 6.4 (Sep 19 2026, build 6426), FW 1.5
Thanks for the help,
Sebastian
Turn off NBIOT provider scan
- mb-pro2_display.jpg (618.59 KiB) Viewed 20 times
Re: Turn off NBIOT provider scan
Update. The display freezing on the logo with the progress bar seems to be related to a custom display template file I used that shows the time. Once I removed this event definition the progress bar disappears and the screen saver (two moving vertical lines) start after a while.
In essence this is the behaviour I want with the only difference that I want to see the time for, let's say, 5 seconds each time the two lines meet. At the moment it shows the IP address under the smartbedded logo. Any advice on how to get the behaviour I want would be much appreciated.
The start of the NBIOT provider scan is still the same. Can this be turned off?
Sebastian
Sebastian
Rei_Studio
- Fresh Boarder
Under Network, do you see an NBIOT tab, and if so what does it list as the module type? The PRO2 documentation describes that tab for units equipped with the optional NBIOT module. Please share only the module type or say that the tab is absent, not the IMEI or SIM identifiers.
