Meteobridge PRO – repeated USB hub resets, internal ATP storage and Meteostick failures
dmcole4
Post by dmcole4 »
Hi Boris,
I’m seeking your advice regarding increasingly frequent reliability problems with my Meteobridge PRO, which has otherwise served me well for almost ten years.
I’ve undertaken some fairly extensive diagnostics over recent weeks and have now captured kernel-level evidence that I hope will help identify the underlying problem.
Current configuration
* Meteobridge PRO (red caps), purchased directly from smartbedded on 8 December 2016, invoice 2016SB142
* Meteobridge 6.4 (16 November 2026, build 15784), FW 1.4
* Meteostick version 3.4
* Davis Vantage Vue ISS, transmitter ID 3, 915 MHz
* Internal ATP NANODURA USB storage
* Active historical database approximately 101 MB, containing around ten years of data
* External front-panel USB stick used for monthly database backups
* Wi-Fi connection via a TP-Link EAP225-Outdoor access point
* SMB enabled (authenticated users only)
* Display normally switched off
Background
Initially, I suspected RF reception problems between the Davis ISS and Meteobridge.
I relocated the Meteobridge to a sheltered outdoor location, approximately 40 metres from the ISS with substantially improved line of sight. This has generally improved RF signal strength considerably, but has not resolved the reliability problems.
I subsequently encountered database errors, Meteostick communication failures and intermittent problems accessing files via SMB.
On 20 November, I replaced the original, nearly full 4 GB Kingston external backup USB stick with a SanDisk 256 GB USB stick configured with a 32 GB FAT32 partition.
The active database remains on the original internal ATP storage.
Unfortunately, the problems have continued.
Recent incidents
On the evening of 27 November, the Meteobridge experienced numerous logging process restarts, accompanied by errors including:
unexpected 0 bytes
can’t set attributes of device /dev/ttyMH113
Input/output error
disconnect station 0 (RF Vantage): response without data
Database errors included:
attempt to write a readonly database
There were repeated USB storage remounts, with device names alternating between /dev/sdc and /dev/sdd.
Another recurring error was:
cannot open display template “Meteostick RF analysis.dsp”: No such file or directory
I have subsequently confirmed that this template is still present and visible through the Meteobridge file management interface.
Despite these incidents, the operating system uptime remained continuous. It appears that the logging processes and USB devices were restarting rather than the entire Meteobridge rebooting.
A further similar incident occurred at approximately 11:55 am on 28 November.
Kernel diagnostics
I retrieved the available kernel log using /cgi-bin/system.cgi?dmesg.
The log identifies the following devices connected through USB hub 1-1:
* Port 1 (1-1.1): SanDisk external backup storage
* Port 3 (1-1.3): FTDI FT232RL serial interface
* Port 4 (1-1.4): ATP NANODURA internal storage
The available kernel log contains:
* Eight USB hub resets.
* Twenty-four USB device disconnections.
* Six instances of the EXT4 filesystem being remounted read-only.
Representative messages include:
usb 1-1: clear tt 1 (91f1) error -71
hub 1-1:1.0: Cannot enable port 4. Maybe the USB cable is bad?
Buffer I/O error on device sdc, logical block 65536
lost page write due to I/O error on sdc
EXT4-fs (sdc): Remounting filesystem read-only
usb 1-1: reset high-speed USB device number 2 using ehci-platform
All three USB devices disconnect and subsequently reconnect during the hub reset sequences.
There are also numerous Wi-Fi authentication and association timeout messages, although I am unsure whether these are related.
The attached kernel log (ZIP archive containing a text file) has been sanitised to anonymise my wireless access point’s MAC address. The diagnostic messages and timestamps have otherwise been preserved.
System health
I have attached both two-day and seven-day MBPRO-health charts, generated on 28 November at hourly resolution.
These show:
* Generally stable reported supply voltage of approximately 5.44 V.
* Regular daily temperature fluctuations, with base-board temperatures broadly between 37°C and 53°C.
* Some power consumption spikes.
* Some elevated RAM utilisation, but no obvious progressive increase.
* Continuous system uptime.
I appreciate that hourly measurements may conceal brief voltage fluctuations or other transient problems.
Internal storage currently reports 681 MB free (21% used), with an estimated remaining lifetime of 83.1 years.
Given that the Meteobridge is almost exactly ten years old, I recognise that age-related degradation of one or more hardware components is a possibility. The original purchase date may also help identify the hardware revision.
Questions
I would particularly appreciate your advice on the following:
1. Have you encountered this pattern of USB hub resets, port 4 errors and internal storage failures previously?
2. Does the kernel log suggest that the ATP storage itself is failing, or could the USB hub, power supply, internal connections or firmware be responsible?
3. Is there any additional diagnostic information I could collect to help distinguish between these possibilities?
4. Would you recommend testing with an alternative power supply, disabling SMB or temporarily removing the external backup USB stick?
5. Is the internal ATP storage safely removable and replaceable by the owner?
6. Would there be merit in independently imaging and testing the ATP storage on another computer? I have a SpinRite licence, although I would obtain a sector-level image before undertaking any potentially destructive testing.
7. If the ATP storage is faulty, are suitable replacement industrial-grade storage devices available? Alternatively, could the Meteobridge operate reliably using external USB storage with the internal ATP removed?
8. Given the age and hardware revision of my Meteobridge PRO, what is your assessment of its ongoing serviceability? If a hardware fault is confirmed, would repair be technically and economically worthwhile compared with replacement?
9. Would you be interested in remotely diagnosing the unit?
I have preserved my historical database backups, obtained fresh database backups on 20 and 28 November, and downloaded the current Meteobridge configuration.
I am reluctant to undertake filesystem repairs, hardware modifications or database migration until I have a better understanding of the underlying problem.
Further application logs, configuration details and RF diagnostic data are available if required.
Many thanks for your assistance.
Meteobridge-dmesg-2026-11-28-sanitised.zip
Sanitised dmesg kernel log – 28 November 2026.
(11.5 KiB) Downloaded 1 time
Meteobridge PRO health – 2 days, hourly resolution
Meteobridge PRO health – 7 days, hourly resolution.
