Wind in graphs when there´s no wind because it´s calm
wfpost
Post by wfpost »
Is there a chance to change the drawing for wind direction in graphs.
Wind directions values are also shown when the current condition is calm.
That is a confusing point if you look at a graph.
Here´s an example what I mean:
How easy might it be to alter the meteohub code and having all wind direction values disappearing when "wind speed=0" ?
Cheers,
W.
Re:Wind in graphs when there´s no wind because it´s calm
I don't know of a simple way to do this, because gnuplot does the drawing.
Introducing something like "no direction" in the aggregated data for gnuplot might have quite a few side effects. I will think about it.
Post by skyewright »
admin wrote:Introducing something like "no direction" in the aggregated data for gnuplot might have quite a few side effects. I will think about it.
In some software (I can't recall if it is WD or WSWIN or both) I think I've seen a (probably optional) feature that direction should report as a specific value (0?) when windspeed is zero.
You choice may vary... :)
wfpost
Post by wfpost »
WSWIN is the one, where I got it from ;)
