Solar intensity not sending to WU after 2.7 update ** solve
bsparks
Post by bsparks »
After the 2.7 update, solar intensity and UV radiation were not sending to Weather Underground. After contacting WU directly, they fixed the problem. However, still the solar intensity is not sending. WU support says they looked at my raw data and it seems to be not coming in from meteohub. Any ideas?
Anxious about this because Gustav will be coming through here soon and I want the station running well.
sevenless
Re:Solar intensity not sending to WU after 2.7 update
Post by sevenless »
I hadn't noticed previously with my own station sending to WU, but sure enough same problem with solar data, using the same setup (VP2Plus, Meteohub 2.7.) Guess it might be a glitch in the Meteohub code?
I believe that Boris is back as of today, so hopefully he can look into it amidst the giant backlog of requests and suggestions we've generated for him :)
bsparks
Post by bsparks »
Glad to know it's not just me. Thanks for the input, and I look forward to seeing Boris's suggestions.
Good finding. Bug will be fixed in 2.7a.
bsparks
Post by bsparks »
bsparks
Post by bsparks »
Updated, but I am not seeing the data. I will keep looking for it to appear and keep you up to date.
@bsparks: It would help, if I could test the new code on your system (as I don't have a vantage with solar sensor here). Could you please provide me access to port 22 (ssh) and 7777 (http) both with tcp protocol? please mail to "info(at)meteohub.de".
I could find the bug with the help of bsparks rig. Update 2.7b should cure this.
wfpost
Post by wfpost »
admin wrote:I could find the bug with the help of bsparks rig. Update 2.7b should cure this.
yep; a new graph for SOLAR also appears with my WU station:
http://www.wunderground.com/weatherstat ... =IHONSOLG2
No Data yet, but lets wait until tomorrows sun rise.
