Meteohub Update 2.7b (experimental)
What's hot...
DEUTSCH:
Änderungen gegenüber V2.7a:
* Behebt einen mit 2.7/2.7a eingefügten Fehler bei der Übermittlung von Solarstrahlungsdaten an Wetternetzwerke.
* Behebt einen Fehler beim Template-Ersetzungsprozess, wenn das Template geschweifte Klammern "{" enthält.
* Tauscht die Position von Längen- und Breitenangaben auf der Seite "Einstellungen".
* Stellt nun auch Solarstrahlungswerte für das Wetternetzwerk "meteoclimatic" zur Verfügung.
ENGLISH:
Changes since V2.7a:
* Fixes a bug introduced with 2.7/2.7a that inhibits reporting of solar radiation data to weather networks
* Fixes a bug in template replacement process, that damages the template when "{" characters are in there.
* changes position of longitude and latitude in settings page.
* Supports reporting of solar radiation to weather network "meteoclimatic".
wfpost
Re:Meteohub Update 2.7b (experimental)
Post by wfpost »
Just saw that solar variables have changed, because it gave me wrong entries in my webpage.
What value does
day1_sol0_radiation_wqm
stand for?
Average?
And day1_uv0_index.
Also average for the current day?
day1_uv0_index 1.9
day1_uv0_indexmax_time 20080831130915
day1_uv0_indexmax 6.6
day1_sol0_radiation_wqm 292.4
day1_sol0_radiationmax_time 20080831133859
day1_sol0_radiationmax_wqm 802
day1_uv0_index 1.9
= average over the actual day til now
= max of the actual day til now
= average of the actual day til now
day starts at 00:00 local time
wfpost
Post by wfpost »
admin wrote:day1_uv0_index 1.9
I see.
my meteohub exports the data to wswin
Strange that the averages do not really match ...
I wonder why the maximum values are slightly below in the exported data to wswin
Meteohub is averaging very simple starting at midnight.
Can it be that WSWIN is just making use of data between sunrise and sunset?
