"actual_wind0_dir_de" does show wrong value ** solved **
wfpost
Post by wfpost »
when variable "actual_wind0_dir_de" is used with IFRAME as described in the manual it does show the angle in degrees, but not the text.
<iframe src="http://adr.homedns.org/meteograph.cgi?t ... nd0_dir_de"
frameborder="0" scrolling="no" width="33" height="14" marginwidth="5"
align="left" marginheight="2">n.a.</iframe>
Instead I used the 'en' version, that works, but English is not very suitable with German websites:
<iframe src="http://adr.homedns.org/meteograph.cgi?t ... nd0_dir_en"
two links for checking the bug yourself:
with 'de'
http://www.myway.de/honsolgen/rtde.html
with 'en'
http://www.myway.de/honsolgen/rt.html
Using it without IFRAME gives the correct output for both values:
actual_wind0_dir_de ONO
actual_wind0_dir_en ENE
Can that be fixed? Thanks
P.S.
Another thing that would be great to have, if the text color of the embedded variables could be changed.
IFRAME does not allow the black font to be altered to any other color. Is there anything you can add an option to select RGB colors?
How is the variable processed when using the IFRAME code? Directly parsed from an XML-file on the meteohub?
wfpost
Re:"actual_wind0_dir_de" does show wrong value
Post by wfpost »
after updating to 2.7e the output with
is now empty :blink:
solved with 2.8 (hot fix today at 20:15)
wfpost
Post by wfpost »
