altering the pressure (hpa) reading...** solved **
Hardware topics that do not fit in one of the other categories
binbags
Post by binbags »
Hi Boris
If I use the wmr928 I can alter the pressure readings to suit altitude, as I am using the rfxcom how do I do the same. I can see settings in the meteohub settings and station sections, I have tried these to no avail. :unsure:
example wmr928=971hpa, true= 1001hpa
alan
Re:altering the pressure (hpa) reading to true
Hi Alan,
tell Meteohub your station's height and press save (on settings page), select \"compute based on weather station's height\" and press save (on weather station page) and do a recomputation (on maintenance page).
Wait 15 min and this should do the trick.
Now you can choose in your graph definitions when selecting a pressure sensor whether to use your stations pressure (thb0) or corrected to sea level (thb0-sea).
binbags
Post by binbags »
Hi Boris
Thanks once again for your answer to my sea level query, this has solved my problem:cheer:
alan
