{math- val1 val2 ... valn}
Post by skyewright »
We were recently given {math* val1 val2 ... valn}.
Thank you.
i.e. subtraction, would be nice too.
e.g. {math- 2 5} => 2 - 5 = -3.00
Why?
With that I could easily compute and use the difference in temp between sensors, e.g. the difference between the main outdoor temp and my "temp in a jar" solar sensor.
Of course, if Boris wanted to add the ability to do subtraction in some quite different way, that would be just as good. :)
Re:{math- val1 val2 ... valn}
I guess you are the only one out there using this math feature :ohmy:
I had to invent the math-stuff to enable the html template replacing mechanism to generate the quite weird data for WD-live clientraw files.
"mathlrot" is needed to rotate daily/monthly values from the sequence strings to sort the data correctly for WD-Live bar charts.
"mathmax" is needed to inhibit yearly, monthly, daily values for total rain showing inconsistent values when not all has been yet computed.
I will include "math+" with the next update. You can subtract values by putting a "-" before the variable name. For example: "{math+ -[actual_th0_temp_c] [actual_thb0_temp_c]}" will give difference between indoor and outdoor in degrees Celsius.
admin wrote:I had to invent the math-stuff to enable the html template replacing mechanism to generate the quite weird data for WD-live clientraw files./quote]
I sort of guessed that from the timing. ;)
Thank you. That will do nicely. :)
PS. Over on Weather-Watch.com someone has recently spotted that a "temp in a jar" solar can also be used to give a basic indication about night time skies too - on an overcast night the jar is about the same temp as the standard outdoor, and on a clear night it is distinctly cooler. I'm currently doing tests on this and trying to refine my jar...
skyewright wrote:Thank you. That will do nicely. :)
This was included in v2.8a.
Just tried it out, and it works just fine. :)
Thanks again.
