Calibrating the sensors ** solved **
WH-1080 weather station is also known as Watson W-8681, WX-2008, National Geographic 265 NE, Elecsa 6975 and 6976.
argonaut71
Post by argonaut71 »
When using WH-1080 device I cannot find any sensors from calibrating drop down menu. So it is possible to calibrate this device?
argonaut71
Re:Calibrating the sensors
Problem solved by myself.
I need to name those sensor before they appear to the drop down menu.
especially, you have to press save on the sensors page to make these registered.
