Possible "When is Today" issue?
Post by skyewright »
Using Meteohub 2.8a
I've just noticed that on my simple internal HTML summary page (copy attached - as zip because joomla doesn't like htm) the "Max Gust Speed" for "Today" (i.e. [day1_wind0_gustspeedmax_mph] and [day1_wind1_gustspeedmax_mph])are showing as 23:37, which is a value from yesterday.
At present we are on Summer Time here in the UK, but that doesn't quite seem to be the explanation because we are 1 hour ahead of UTC, not behind it. 23:37 local time, would have been 22:37 UTC, i.e. both 'yesterday'.
I don't recall seeing this before... [file name=Mini_Dashboard.zip size=2448]http://www.meteohub.de/joomla/images/fb ... hboard.zip[/file]
Re: Possible "When is Today" issue? - ** SOLVED **
skyewright wrote:Using Meteohub 2.8a
I later found that all "day1" values were resetting at 23:00 local time (22:00 UTC).
Installing version 2.8b, then doing a recompute has solved the problem. :)
