Data logging stopped? ** solved **
giantmr4
Post by giantmr4 »
I find my meteohub stop logging data for over 10 hours and all are in red colour in sensor page.
However, WMR100 console is functioning and there is no \"---\" shown.
Any advice to me to fix this problem? :blush:
System Info page:
MeteoHub: Version 1.8b (c)2008 by Boris Pasternak, info@meteohub.de
ProcessWeather Data Recomputation: completed
Weather Data Logging: running (last data: 10 h)
SSH Login: running
SMB Shares: running
Time Synchonization: running
Alarm log:
2008.02.05 17:44:38 meteohub: sensorfail: Sensor \"rain0 (PCR800) wind0 (WTGR800) thb0 (WMR100) th0 (WTGR800) th1 (THGR810) \" failed
2008.02.05 17:44:38 meteohub: datalog: Logging of Weather Data for more than 30 minutes without new data
all-sensors.txt:
actual_utcdate 20080205111701
actual_utcdate2 05.02.2008 11:17:01
actual_localdate 20080205191701
actual_localdate2 05.02.2008 19:17:01
actual_thb0_temp_c 16.3
actual_thb0_temp_f 61.3
actual_thb0_hum_rel 65
actual_thb0_hum_abs 0.8
actual_thb0_dew_c 9.7
actual_thb0_dew_f 49.5
actual_thb0_press_hpa 1010.0
actual_thb0_press_psi 14.65
actual_thb0_press_mmhg 757.5
actual_thb0_press_inhg 29.84
actual_thb0_sealevel_hpa 1018.4
actual_thb0_sealevel_psi 14.77
actual_thb0_sealevel_mmhg 763.8
actual_thb0_sealevel_inhg 30.09
actual_thb0_fc 1
actual_thb0_sensorfail 1
actual_th0_temp_c 13.2
actual_th0_temp_f 55.8
actual_th0_hum_rel 79
actual_th0_dew_c 9.6
actual_th0_dew_f 49.3
actual_th0_hum_abs 0.8
actual_th0_sensorfail 1
actual_wind0_dir_deg 248
actual_wind0_dir_de WSW
actual_wind0_dir_en WSW
actual_wind0_gustspeed_ms 0.0
actual_wind0_gustspeed_kmh 0.0
actual_wind0_gustspeed_mph 0.0
actual_wind0_gustspeed_kn 0.0
actual_wind0_gustspeed_bft 0.0
actual_wind0_speed_ms 0.0
actual_wind0_speed_kmh 0.0
actual_wind0_speed_mph 0.0
actual_wind0_speed_kn 0.0
actual_wind0_speed_bft 0.0
actual_wind0_chill_c 13.3
actual_wind0_chill_f 55.9
actual_wind0_sensorfail 1
actual_rain0_rate_mm 0.0
actual_rain0_rate_in 0.00
actual_rain0_total_mm 99896.9
actual_rain0_total_in 3932.95
actual_rain0_sensorfail 1
actual_uv0_index 0
actual_uv0_sensorfail 1
actual_th1_temp_c 13.0
actual_th1_temp_f 55.4
actual_th1_hum_rel 81
actual_th1_dew_c 9.8
actual_th1_dew_f 49.6
actual_th1_hum_abs 0.8
actual_th1_sensorfail 1
Re:Data logging stopped?
hmmmm looks like complete usb connection is not working. This can happen with usb hid devices (wmr100, wmr200) when you stop logging and then start logging too early (waiting 90 secs is recommended). Then one of the low level processes might get stalled and blocks incoming data.
This will be fixed with 1.8d. No waiting required then :-)
For the moment, please do a reboot (maintenance page). That should solve it.
giantmr4
Post by giantmr4 »
Thx Boris. :)
I try the following ways in sequence to solve the problem temporarily.
1. Unplug the usb cable and wait for some minutes and plug it into the meteohub again --> not work
2. Reboot the meteohub --> still not work
3. Unplug the usb cable, reset the WMR100
console, wait for some minutes and plug the cable into the meteohub --> now work :woohoo:
You are right, there should be some problem on the usb connection, but not sure the problem originates from the console or the meteohub. :blush:
I will try to update it to the new version and let me see and monitor. :)
