Meteohub Update 2.8c (experimental)
What's hot...
DEUTSCH:
Nur ein paar kleine Änderungen.
Änderungen gegenüber V2.8b:
* Abbruch der Datenaufzeichnung beim Ausfall des Sensors th0 bei der Vantage wurde behoben.
* Der Versuch der Übertragung von Windtemperaturdaten an WSWIN wurde wieder rückgängig gemacht.
* Die Clone-Funktion wurde erneut überarbeitet. Bitte testen.
ENGLISH:
Just a few minor bug fixes
Changes since V2.8b:
* Bug that causes data logging to abort an a failing vantage th0 sensor has been fixed.
* Failed attempt to deliver Wind temperature to WSWIN has been rolled back. All additional sensors can now be used as regular temp/hygro sensors.
* Clone functions has been reworked. Please test.
Chill
Re:Meteohub Update 2.8c (experimental)
Post by Chill »
Cloning doesn't work for me.
When you first click to CLONE there's no message when you can notice if anything is happening:unsure:
When finished it restarted meteohub, with any notification:unsure:
Then I turned off system, I changed USB stick in disk 2 with the new one, and restarted again. meteohub is unreachable.
I'm trying to clone a 2Gb USB from disk 2 to 2 Gb USB in disk 1.
HTH,
Chill
G3ZSS
Post by G3ZSS »
I successfully cloned my 4GB USB stick today (2.8c).
On the first attempt I pressed the clone button, before removing my Davis Weather station from Disk 1 and the cloning failed. On the second attempt, I replaced the Weather Station with the new USB stick before starting the clone. This needs to be mentioned in the manual.
Peter
