meteohub - kind of strange reboot
Unconnected
Post by Unconnected »
suddenly i noticed that my weather-data was not being updated.
i checked the meteohub but it wasn't accessible with its normal ip. so i checked the dhcp-list and the ip changed (allthough the ip was set to 'fixed' in meteohub)
trying to access the webpage on it failed... so i ssh'ed to it. the passwd was still meteohub so i thought everything was fine, but the output of ps and ls gave me something not quite 'meteohub-like':
[root@server evert]# ssh 192.168.0.15
root@192.168.0.15's password:
root@LKG288307:~$ ps w
PID Uid VmSize Stat Command
1 root 564 S init [3]
2 root SWN [ksoftirqd/0]
3 root SW< [events/0]
4 root SW< [khelper]
5 root SW< [kthread]
38 root SW< [kblockd/0]
41 root SW< [khubd]
56 root SW [pdflush]
57 root SW [pdflush]
58 root SW< [kswapd0]
59 root SW< [aio/0]
81 root SW [mtdblockd]
82 root SW [nftld]
234 root 588 S < udevd --daemon
504 root SWN [jffs2_gcd_mtd4]
516 root 608 S /sbin/syslogd -n -C 64 -m 20
518 root 600 S /sbin/klogd -n
707 root 260 S udhcpc -n -p /var/run/udhcpc.eth0.pid -i eth0
751 root 624 S /bin/sh /root/stickit
775 root 912 S /usr/sbin/sshd
805 root 544 S /sbin/getty 115200 ttyS0
886 root 2000 S sshd: root@pts/0
890 root 852 S -sh
897 root 436 S sleep 10
898 root 748 R ps w
root@LKG288307:~$ uptime
01:59:10 up 3 min, load average: 0.19, 0.29, 0.12
root@LKG288307:~$
root@LKG288307:/$ ls -la
drwxr-xr-x 19 root root 0 Jan 1 1970 .
drwxr-xr-x 19 root root 0 Jan 1 1970 ..
drwxr-xr-x 2 root root 0 Jan 1 1970 bin
drwxr-xr-x 2 root root 0 Jan 1 1970 boot
-rw-r--r-- 1 root root 119913 Mar 4 2008 data.tgz
drwxr-xr-x 10 root root 1480 Oct 24 02:01 dev
drwxr-xr-x 20 root root 0 Oct 24 02:00 etc
drwxr-xr-x 2 root root 0 Jan 1 1970 home
drwxr-xr-x 2 root root 0 Jan 1 1970 initrd
drwxr-xr-x 5 root root 0 Jan 1 1970 lib
-rwxr--r-- 1 root root 149 Mar 1 2008 linuxrc
lrwxrwxrwx 1 root root 10 Jan 1 1970 linuxrc.sav -> boot/flash
drwxr-xr-x 12 root root 0 Mar 25 2008 media
drwxr-xr-x 2 root root 0 Jan 1 1970 mnt
drwxr-xr-x 3 root root 0 Mar 4 2008 opt
dr-xr-xr-x 37 root root 0 Jan 1 1970 proc
drwxr-xr-x 3 root root 0 Mar 13 2008 root
drwxr-xr-x 2 root root 0 Jan 1 1970 sbin
drwxr-xr-x 10 root root 0 Jan 1 1970 sys
lrwxrwxrwx 1 root root 8 Mar 1 2008 tmp -> /var/tmp
drwxr-xr-x 10 root root 0 Jan 1 1970 usr
drwxr-xr-x 7 root root 0 Jan 1 1970 var
root@LKG288307:/$
the hostname had changed and none of the meteohub stuff was running. i gave a reboot and it came back to this state.
i had it before and only a hard reset (turn off/on) fixed it, so i'll try that tomorrow (i'm not at home right now). did anyone notice this as well?
Re:meteohub - kind of strange reboot
the ps output and command line prompt indicate that Meteohub was not able to boot the USB stick.
Boot process is done in two steps. Step 1 is booting the limited SlugOS from NSLU2 firmware, then full-fletched Meteohub is booted from USB stick. For some reason the system does not do the second step. I had this once with a certain USB stick. After working some while this USB stick could not be started (just on every second attempt) for sure. Changin the stick solved this.
Unconnected
ok, but the strange thing is... i didn't reboot the nslu2 for this situation to happen. it just got into this mode...
and a few software-reboots didn't fix anything, only a hard reboot (turning it on/off) :dry:
