I'm using a WMR-100 with Meteohub v3.0b and WDL v6.03. Everything seems fine expect, when it's raining, the rainfall rate is wrong.
WDL shows 60x the actual rate. For instance it shows 3.0 mm/min (or 180 mm/hr depending on the WDL configuration) when it should show 3.0 mm/hr.
It's not my WDL set up, because it works OK if I feed it from WD instead of Meteohub, and the same problem shows up on the WDL preview within Meteohub itself ('display and save' under the WD Live menu).
Have I missed something in the Meteohub setup to tell it to divide the WDL rainfall rate by 60? Oddly, the rainfall rate reported by Meteohub to my Weather Underground account is fine, it's just WDL. Also the rainfall totals in WDL are right, it's just the rate.
Any ideas anyone?
Mark.
Wrong rainfall rate displayed in WD-Live ** solved **
- Senior Boarder
- Senior Boarder
Re:Wrong rainfall rate displayed in WD-Live
Solved in v3.2. Thanks!
