Use a RS232 converter with FTDI chip for Vantage!
The cheap RS232/USB converter with a prolific PL2303 chip in it
seem not to work with the Vantage. Please take one with a FTDI chipset
when connecting a Vantage to a Meteohub.
Shops in Germany that have FTDI-based converter:
cbhiii
Re:Use a RS232 converter with FTDI chip for Vantage!
Post by cbhiii »
I just got my new system all set up and I waited to order a USB/Serial adapter until I could try out the one I own. It is a Keyspan USA-19HS, but it does not work unfortunately. It works with the PC to Vantage Pro2 though.
The links you gave me for a FTDI chip are from shops in Germany, but I can't read any of the pages to try and find a match here in the United States. Can you tell me more about the kind of FTDI chip that I need to be installed into the USB adapter or who makes them here?
cbhiii
Post by cbhiii »
I think I found one. Can you look at this one?
TECH NOTES: CableMAX USB 2.0 FTDI CHIP Ultra Fast USB Serial RS-232BCL Part Number of this USB to Serial Adapter!
This one too looks like it might work.
both do look ok to me.
jonn68
Post by jonn68 »
Which RS232 is the best for the Vantage Pro2?
1.
http://www.so-mm.de/USB-20-RS-232-Konve ... 5af_x2.htm
2.http://elmicro.com/de/kabelusb.html
Jonn
cbhiii
Post by cbhiii »
Here's a good source for FTDI cables in the USA.
http://www.serial-usb-adapter.com/
I just ordered the 1 foot model for under $24 delivered.
** UPDATE **
Cable installed and working fine. :)
