Problem with WMRS 200 and indoor T/H in WDL
minapija
Post by minapija »
In meteohub version 3.1 I find out, that if I assign at WD LIVE page setting sensor THB0 for indoor temp and hum (I use WMRS 200 with meteohub), that clientraw.txt contains too many parameters repeated and from this reason is this file corrupted and WDL get data error after loading. When I hide sensor for indoor temp and hum in this page for WD LIVE settings, generated file is normal and all is fine. Does anybody have similar problems with clientraw.txt?
Data from clientraw.txt looks like:
12345 0.0 0.0 338 23.7 36 1030.6 0.00 0.00 847.70 0.0 0.0 24.4 31 - 2 - - 0 0.0 - - - - - - - - - 13 49 00 13:49_WMR_200 0 - 14 11 - - - - - - - 23.7 24.0 24.1 22.0 2 _ -1 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 7.8 6360 14/11/2008 25.4 22.6 24.1 22.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 23.7 23.6 23.6 23.5 23.3 23.2 23.0 22.7 22.2 22.2 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 24.1 22.0 23.7 0.0 0 _ _ 337.5 _ 0 - - - - - - - - 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 22.4 24.7 24.8 24.9 24.0 22.8 23.3 25.1 24.4 24.8 23.2 24.2 23.1 23.2 25.1 25.4 24.4 24.4 24.4 24.4 24.4 24.4 24.4 24.5 24.5 23.5 23.8 23.6 25.2 24.5 25.2 24.8 25.2 25.6 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 22.2 21.9 22.1 21.6 21.6 21.7 21.9 21.4 21.8 21.6 21.2 20.8 20.8 21.3 21.0 23.4 20.5 20.5 20.5 20.5 20.5 20.5 20.5 21.3 21.3 21.1 21.2 21.1 21.2 21.7 21.7 22.0 21.7 21.2 - - - 0.0 _ _ - - 10.0 7.7 0.0 2008 _ 0 0 0 338 338 338 338 338 338 338 338 338 338 - - 0.0 - 49.216389 16.640833 !!C10.37kf!!
AAMFlyer
Re:Problem with WMRS 200 and indoor T/H in WDL
Post by AAMFlyer »
I'm using 3.1 and WDL and haven't seen that - but sometimes I find that going through and re-saving all your settings - basically go through each page and just hit save again and then recompute agregate data and see what happens....just a thought as that fixed some issue I had a few versions ago...
G
I tried to reproduce your finding with 3.1 but I can't. Adding indoor temp didn't put any harm to my "clientraw.txt".
Is there a way for me to login to your system on port 22 to inspect the detials?
