Meteohub 3.2 - cannot access the web interface
Merzer
Post by Merzer »
Hi, I am running Meteohub 3.2 on the Microclient Jr. hardware.
Since I upgraded to Meteohub 3.2 yesterday, I can no longer access the web interface if I enter the IP address in my web browser. It all worked fine with 3.0 and 3.1, the configuration of the network or of the computer has not been changed. Meteohub seems to run fine on the Jr., Debian and Meteohub start without any problems.
One more question: how can I access the SMB directories provided by Meteohub from my Windows PC? Using the older NSLU2 hardware, I could simply access them using the Network Neighbourhood symbol of Windows XP. Since I switched to the Microclient, I get an error message telling me "I have no rights to access". Again, the network configuration and compouters have not been changed.
Thanks in advance.
bolzano
Re:Meteohub 3.2 - cannot access the web interface
Post by bolzano »
hi,
For the SMB share, just try \\\\meteohub from the run menu (in the start menu or Windows+R)
Merzer
Post by Merzer »
Unfortunately, that does not work - it tells me "network path not found".
how did you upgrade?
New USB Image to setup system from scratch or update via Meteohub web interface?
I upgraded a MC Jr. via web interface from 3.0 to 3.1 and then 3.2 and all looks fine.
Mine is beeping th IP quite loud. May be you want to place a file named "noreadip" in "/public/log/" to get this silenced.
Merzer
Post by Merzer »
I reinstalled the software from scratch. However, I will try today to downgrade to the older version and then apply the updates.
Merzer
Post by Merzer »
Good news: I installed 3.0 and then applied the updates 3.1 and 3.2 Now everything works fine, including SMB access. Maybe something went wrong with my installation of 3.2 from scratch yesterday.
