error connect socket 127.0.0.1:5555 :Connection refused
Darkfiremn
Post by Darkfiremn »
Help I am getting this msg when the meteohub hub activates. "
error connect socket 127.0.0.1:5555 :Connection refused"
Re:error connect socket 127.0.0.1:5555 :Connection refused
This message indicates that the data logging process has been halted or gets periodically restarted because no data can be received.
Please look at "meteohub log" entries on "log files" page. What does it say there?
Darkfiremn
i think this is what you want:
Cant open device /dev/ttyusb0: no such file or directory
looks like your RS232/USB converter is not recognized. What type do you use?
Darkfiremn
its one i got off of e-bay. it was working with my HP laptop.
What kind of weather station? vantage or wmr-968/928?
Darkfiremn
its a wmr-968
Then you can go for a cheap pl2303 based converter.
Try "ebay.com", search for "RS232 PL2303". They start from $7 incl. shipping.
fil
Post by fil »
All of a sudden after a reboot I'm also getting this error. My cable is obviously OK. In the main page I have the following errors:
Error file open: /var/run/loggerd.pid: No such file or directory
Error file open: /var/run/dropbear.pid: No such file or directory
Error file open: /var/run/meteonet.pid: No such file or directory
Error file open: /var/run/smbd.pid: No such file or directory
Log files are empty. I tried an web update and I get: "Checkinging md5sum of update 4.4 failed (generate diff)!". I can't access meteohub through SSH. Seems my meteohub system has gone havoc... :angry:
Is there anything I can do besides starting all over?
fil
Post by fil »
Well I reinstalled meteohub (again). Now I tried to restore my settings and this is what I get:
Wrong Format. Settings have not been loaded.
Unbelievable... :angry: I have several backups and none of them works. What can I do? And how do I restore the meteohub.backup file?
