Weather Data Recomputation: waiting... for days
atsea
Post by atsea »
OS WMR200
Meteohub 3.2
Since some days I have following problem;
Message in System screen:
Message in Log screen
2008.12.14 23:04:55 meteohub: weathernet: meteoclimatic: error open file /srv/www/meteoclimatic.txt: Read-only file system
2008.12.14 23:24:26 meteohub: weathernet: meteoclimatic: error open file /srv/www/meteoclimatic.txt: Read-only file system
2008.12.14 23:44:41 meteohub: weathernet: meteoclimatic: error open file /srv/www/meteoclimatic.txt: Read-only file system
2008.12.15 00:03:58 meteohub: weathernet: meteoclimatic: error open file /srv/www/meteoclimatic.txt: Read-only file system
In screen sensors I see no sensor until I search since the station but after a few hours they are lost again.
Any idea to solve this problem will be very wellcome.
thank you
Re:Weather Data Recomputation: waiting... for days
Your USB sticks file system has gone bad and Linux switched it to read only. If you are very very lucky, a reboot might fix it for the moment.
But I fear you will have to set up a new stick.
Please copy all your weather data to your PC.
A complete backup of all weather and user data can be done with "application backup" function on "maintenance" page. When finished (will take a couple of minutes) copy "/public/meteohub.backup" to your PC.
atsea
Post by atsea »
My old stick has past away completelly. I have now my MNSL and a blank stick... how can I setup again meteohub?.
By the way, I have to 4G stick converted to 422MB for any reason my computer recognizes only 422MB, any advice how to recover them?.
Thank you in advance
Chill
Post by Chill »
Don't get panic ;)
422 Mb is the size Windows can recognize after being formatted into a Linux format.
Do not throw it!
I'd try to low_format level the USB. After this you may download last meteohub Image Stick and install it following the instructions (very easy indeed).
You may look low-format freeware in google.
Once you have this working update to the last version and restore data (if you have done backup)
HTH,
Chill
