I would like to kow if anybody has been able to get Weather Display to work with Meteohub using Davis Vantage Pro2 and a Davis USB Data Logger. Reason I ask is ai found a great web templat at http://www.carterlake.org/webtemplates.php
This web template pulls data from Weather Display but I can't seem to get the Weather Display ssoftware configured correctly to get data from Meteohub. Any hints or suggestions are welcome.
Can Meteohub feed Weather Display Software via USB
Re:Can Meteohub feed Weather Display Software via USB
I have. There are some notes here.kalib897 wrote:I would like to kow if anybody has been able to get Weather Display to work with Meteohub...
When using the logging protocol WD only knows that it is talking to Meteohub. It doesn't know what sort of weather station is 'feeding' Meteohub, so I don't think it should make any difference what you are using....using Davis Vantage Pro2 and a Davis USB Data Logger.
