Hi
How can i change the dashboard language to portuguese ?
Best regards
Change Dashboard Languge ?
Re:Change Dashboard Languge ?
You will need to create the translation yourself -- to the best of my knowledge, no one has created one yet.
Instructions and a template are provided in the Downloads, under the Meteohub Language Files section, with details about how to use the resulting file outlined in the Appendix of the user manual.
I've created the translation. I send the file. But the dashboard doesn't work in portuguese. You know why? [file name=portugal_utf.zip size=9501]http://www.meteohub.de/joomla/images/fb ... al_utf.zip[/file]
I forget to say that MTEOHUB work ok in portuguese
Unfortunately I don't know if the dashboard uses the translated language files. You will have to wait for Boris (the admin) to answer.
Hello.
I have a problem with my language pack after upgrading to 3.3b. The menu in tle left corner is not translated anymore... In the language pack everything seems to be ok, but it is not shown (everything else is ok)...
Any idea Boris? If I choose the "Deutsch" or "English" it is shown...
"00|System Info|Log Files|Settings|Sensors|Inspect Data|Maintenance|Define Graphs|Manage Graphs|Setup Push Services|Graph Uploads|Weather Networks|WSWIN Data Export|WD Data Export|Weather Station|Webcam|Dashboard|WD Live|License::sistemske informacije|logiranje podatkov|nastavitve|senzorji|preveri podatke|vzdrževanje|določi grafe|urejaj grafe|spletna obvestila|FTP nalaganje grafov|vremenska omrežja|WSWIN izvoz podatkov|WD izvoz podatkov|vremenska postaja|spletna kamera|uporabniški vmesnik|WD Live|licenca
Regards, Uros
Regards, Uros
