Meteohub update frequency will temporarily slow down
What's hot...
As you are used to see frequent experimental updates, I would like to let you know that update-speed will go down a bit in the next weeks. Reason is is quite straight forward. After having developed the code for over a year, the code base needs some architectural rework, to be able to handle the next wave of expansions.
So don't be alarmed, the Meteohub project is up and running, even when you won't see much updates in the next weeks.
