using meteohub with pc-weather
binbags
Post by binbags »
Hi Boris
The old problem of importing the .csv file into wswin has reared its head again.
I have the box ticked to generate the english date format, but pc-weather is asking for dd/mm/yyyy not the one stored dd.mm.yyyy.
From memory you provided me with a small upgrade, but because of my pc problems I have lost all files.
regards
alan
Re:using meteohub with pc-weather
Hi Alan,
Werner told me that the updated WSWIN version he has sent to you does no longer need the switch.
So please don't select the \"English date format\" on the WSWIN config page in Meteohub.
vorkus
Post by vorkus »
I'm having the same problem. The date format won't let me import the csv file. I don't see the English date format option mentioned in the first post.
Any help would be appreciated!
John
