Problem with Italian Language
Casappa
Post by Casappa »
Hallo',
there is a problem.
If I change to italian language, the left menu' it is always in UK or DE and never in ITA.
Can you update this please?
Thank you
Alberto.
Re:Problem with Italian Language
The structure of the menu has changed (one new entry). When a language file is used that does have a not matching number of menu entries, the translation line is not used and the English original appears.
Updating the language file to the new version (can be done by a keypress with meteohub) will bring it to the correct structure. non matching translations are skipped. When you add these again to the file, it will work again.
I try to ninimize changes in menu structures, but I had to separate the network stuff from the settings dialog (two much on one page).
Casappa
Post by Casappa »
I done the Lang file upgrade, but when I switch to italian lang, the network menu' it is lost.
The new network menu' it is available only in germany or english
Help please.
Alberto.
Please send me the language file, so that I can inspect it here.
Casappa
Post by Casappa »
I download the ita lang file from your website here:
http://www.meteohub.de/joomla/index.php ... &Itemid=29
The network entry was missing in the menu translation. SO it was ignored. By updated the language file automatically this "wrong" structured entry was sorted out and appended to the list of translations still to be don (at the end of the language file). I put in a structural correct translation and uploaded the file again. Italian has an Italian Menu again, other languages may be impacted the same.
If you like, you can add some more Italian to it. There are quite a bunch of new sentences to be translated. I am happy to upload it.
Casappa
Post by Casappa »
Hi, I done a new update and now does work in italian as well.
Thank You for your intresting.
Alberto.
