Weather Networks Page Error
EmjayNet
Post by EmjayNet »
I was playing around with the data sent to WU on the Weather Networks Page, and I selected a "Temp. #2" sensor to see what difference it made to WU.
The problem is I can't unselect the "Temp. #2" now.
If I use the drop down box to select blank and then save it keeps coming back with the same sensor as before. I can change the "Temp. #2" sensor but not remove it?
EmjayNet
Re:Weather Networks Page Error
Post by EmjayNet »
This is not a serious problem.
I have had to stop using Meteohub sending data to WU because they don't seem to like to extra sensor data i'm sending, and I can find no way to remove it except by doing a complete reset.
Is it my fault in my setup or a error in Meteohub.
I can confirm that this is a bug. Will be fixed with next update.
