I've bought a fit PC without SSD or HD. I've tried to install Meteohub on a USB instead of SSD or HD stick (I've used another USB stick for Meteohub describe in the documentation).
It doesn't work. Do ou know the good parameters in the firmware ? Is it possible ?
Thank
Installation on Fit-PC without SSD or HD but with USB Stick
- Junior Boarder
Re:Installation on Fit-PC without SSD or HD but with USB Sti
Hi!
I´m sorry, but I don´t know any parameters for using a USB stick as boot device.
But I had a lot of problems with the USB stick and the NSLU2. I was very happy with the fit-PC no longer use them. Why don´t you use a SSD? This is very secure and effective.
BTW, this was the main reason for me to switch from NSLU2 to fit-PC.
Jürgen
Jürgen
I don't use SSD only because I've order it since 2 weeks ans I'm still waiting it. :-(
Then I'e tried to find an other solution.
