This morning I needed to add an extra (8th) calibration setting.
As soon as I selected the extra sensor in the empty 'drop-down' list, the form re-drew in a very strange way! See attached (as zip, because as png it was rejected as too wide and too high).
I was able to enter and save the new calibration, and it seems to be effective, but every time I go to the Meteohub Weather Station page it now looks like that!
ALIX 1D, Meteohub 3.3a
Same behaviour on two different Meteohubs. [file name=weather_station_20090111.zip size=24847]http://www.meteohub.de/joomla/images/fb ... 090111.zip[/file]
Corrupt Weather Station form after adding extra calibration
Weather Station form doesn't like an 8th calibration!
...and (just discovered), if I remove that 8th calibration, the page goes back to normal!skyewright wrote:This morning I needed to add an extra (8th) calibration setting.
Strange...
Re:Corrupt Weather Station form after adding extra calibrati
I can reproduce this. It is a buffer overrun error. Will be fixed with the next update.
Thank you.admin wrote:I can reproduce this. It is a buffer overrun error. Will be fixed with the next update.
