Meteohub & Huawei E169 ...
Hardware topics that do not fit in one of the other categories
iw5bt
Post by iw5bt »
Hello, Because i don't have a DSL :angry: i would like to use on Meteohub (on ALIX.1D) a Huawei E169 to transfer data to my web site ... Is possibile?
The system recognizes:
#lsusb
Bus 002 Device 004: ID 12d1: 1001
As is possible connection to my phone company?
Thank you
Stefano
Re:Meteohub & Huawei E169 ...
UMTS support is still very experimental in Meteohub. I encountered a lot of problems when connection is weak, while it seems to work when having good signal.
I cannot promise that it will work, but we could give it a try. Using an UMTS router would be the more reliable solution, but much more expensive.
iw5bt
Post by iw5bt »
HI , Thank you very much for your answer, buy a router UMTS, I think is the best choice for now.
Stefano
acluett89
Post by acluett89 »
Horrible bit of hardware! i had mine for a week before it just completely stopped working, a mate had the exact same problem, even after paying, reinstalling, adjusting the settings and such like,
