Meteohub Bug-Fix Update 3.3c (experimental)
What's hot...
This updates solves connectivity problems with USB Vantages by changing timing of loads/unloads of kernel module cp2101.
If you have an USB Vantage, this update is highly recommended.
link: http://www.meteohub.de/joomla/index.php ... &Itemid=29
Re:Meteohub Bug-Fix Update 3.3c (experimental)
The update above has a bug that stops data logging on USB HID (WMR100, WMR200, RMS300, WRMS200, TE923, WH1080) connected weather stations on NSLU2 platform.
While you read this message, original version 3.3c has been replaced with one no longer having this bug. If you are impacted by an earlier download of 3.3c, please download and install again.
