I've recevied my SSD. I've configured the Bios as described in doc but now I've this mesage : No bootable partition in table
Is it the usb key or SSd  ? How can I check ?
Thank you for your help
						Error in installation No bootable partition in table
				juergen_h.
- Junior Boarder
Re:Error in installation No bootable partition in table
Hi!
It´s important to use the installation instructions written in the last(!) meteohub manual(V3.3). In my case the manual before used some bios settings which generated an installation error. I think, it was the same error you have.
Juergen
Juergen
Thank you. I 've found the issue now.it was the usb stick not compatible.
Now the installation is owrking. Now my issue is to try to be connected thru the web.
It's asking me Username and password. For me root - meteohub but it doesn't work ?
any idea ?
any idea ?
For the web interface the default is meteohub as both username and password.lpfanton wrote:Now the installation is owrking. Now my issue is to try to be connected thru the web.
Perfect ! Thank a lot. I will start to play soon.
