no time zone for Azores
lumes
Post by lumes »
Hello
I´m trying to config my Meteohub, but on Menu "Settings, Date and Time, Time Zone", there are not any alternative for my home (Azores Islands. I have tested varius time zones but no one put time zone for Azores correctly (GMT -1 in winter). Finnaly I inputed manually the time on "New Date & Time", but it does not save that time because some hours after that hour is not there.
Any suggestion for this problem.
Re:no time zone for Azores
You are right, atlantic timezone group (including Azores) is missing in the NSLU2 distribution. This will be added with the next update. Please use the actual matching GMT setting instead of this, until the update arrives.
lumes
Post by lumes »
Hello
Tks for your answer.
-When do you expect to release the new version?
-I Can`nt display graffics with pressure.
In the menu Sensors I have the msg:
24.6° 54% 1024.0mb (1026.4mb) fc:3
and when I try to display a pressure graffic I have the msg:
plot '< /srv/www/cgi-bin/goto.cgi thb0-min5 20090214110000' using 1:11 axis x1y1 title "" with points linecolor rgb "#ff0000" ^ "/tmp/meteoIHI5kv", line 32: all points y value undefined! Content-type: image/png
Any suggestion?
Time zone things should be ok with actual updates (4.1 for example).
Looks like your data is not going to be logged or computed. Did you press "save" on sensors page to register all sensors.
When going to 4.1. you need to setup your weather station and sensors again. Please don't forget.
