Can't start Meteohub
D70
Post by D70 »
After doing the normal installation and change the firmware without problems.
Through the Disk Image, I transfer the file *.Dd into Pen as pointed in the manual.
What happens is that after the downloaded file to the Pen and check that all is well, when I put the Pen of 4 GB in NSLU2 it hangs, the Pen blinks, but the LEDs' disk 1 'and' disk 2 of NSLU2 not blink and it does not respond.
When I try the IP 192.168.1.77 in my browser, it displays an error page to access, where you can read: 'Can not display the page' in the browser.
However, when you ping, the Command Line, and there seems to be the IP address correctly.
It is here that starts the counter intuitive.
When I open a ssh session a get this:
I've tried with diferents PENs, of diferents brands but with no luck...
Re:Can't start Meteohub
Your installation gets stuck in the mini Linux flashed into the firmware. Normally this continues to boot USB stick but that had not happened as I can see from you ssh login.
Reason is, that USB stick has not been setup correctly. When using DiskImage it is crucial that you scroll down the list of target devices until you reach the "Physical Disk" section. Select the USB stick from there (can be recognized from its size).
