Error file open MeteoHub dead
tdfarmer
Post by tdfarmer »
I discovered today that my MeteoHub was not uploading data to WeatherUndergound. I loaded MeteoHub up and I'm getting this message;
Error file open /home/meteohub/meteohub.conf
Demo Version has timed out. You need an activation code for further operation (MAC: 00:13:10:D7:EE:98).
Terms of the license have to be accepted once before Meteohub can be used.
The license text is not in the window, it reads *** not found ***.
If I try and input my activation code it just takes me back to the License Terms page. I'm running MeteoHub ona NSLU2.
Please Help!
TDF
Re:Error file open MeteoHub dead
looks like a corrupted files system on USB stick.
tdfarmer
Post by tdfarmer »
So how do I fix this? Complete re-install:-(
new install on new stick and copying graphs and weather data to the new stick (to avoid loosing too much data).
If you plan to use Meteohub over longer period of time and want a higher degree of system reliability, you might check x86 hw options as an alternative.
