Dashboard no history ** solved **
ab4bama
Post by ab4bama »
I am not getting any history on the dashboard.
ab4bama
Re:Dashboard no history
Post by ab4bama »
Here is the screen shot Image
This happens when a complete recomputation of aggregated weather data is started (manually or by updating the sw or changing other basic things in the Meteohub setup).
When computation is done all should work normal again.
DO you still have the problem?
ab4bama
Post by ab4bama »
Yes, it is still blank. Has been since i upgraded the software to take care of the clock issue a few days ago..
Do you need to remote in to the meteohub??
Also, do you know if they have made any headway with getting the WD to work with the meteohub data stream?
THANKS!!!
yes, please send your connection details via mail to me.
ab4bama
Post by ab4bama »
Just sent login info. THANKS!!!!!!!
I had a look at your system. reason for the problem was that no history data was computed. cron jobs were working fine, but the definition of sensors to take into account was empty.
I suspect this might happen when setting up meteohub and not going to the \"sensors\" page and pressing \"save\" there. Most user do this anyway because they want to give their sensors speaking names.
I pressed the save button and started recomputation of aggregated data on the \"maintenance\" page. I waited until this finished (is indicated on the \"system information\" page).
Now dashboard looks ok and you can define graphs (which has not been working before as well).
