No connection RMS300/ NSLU2
citi
Post by citi »
I have an Oregon RMS300 USB to the NSLU2 With MeteoHub.
When I go to the page "Sensors" there is no sensors.
When I go to the page "Log Files" and select Meteohub Log i have this message :
"logger (11.02.2009 14:38:22): disconnect station 0 (RMS-300).
logger (11.02.2009 14:38:22): connect station 0 (RMS-300).
logger (11.02.2009 14:38:22): unexpected 0 bytes delivered from weather station 0 (RMS-300)"
In the page "weather station" I have that :
"USB serial none
USB HID Oregon WMR-100/200, WMRS-200, RMS-300/600
Type of Connection :USB HID"
How to connect the sensors ?? (one inside of the wheater station and one sensors outside)
Thank you :(
Charles
Matthieu
Re:No connection RMS300/ NSLU2
Post by Matthieu »
I have the same problem with a WMRS-200?. I use version 4.0 rc7.
How to solve this problem ?
Thank you
citi
Post by citi »
I try my RMS300 with Weather Display and it's working well ! The both sensors work inside and outside. (I see in the manual that Meteohub work only with the outside sensor)
So Admin could you help us.....:(
give rc8 a try, which will be released this evening.
Matthieu
Post by Matthieu »
With 4.1 it works ! The sensors are detected and the values are detected.
citi
Post by citi »
Yes now I have temperature and humidity from the sensors. It's working fine.
Do you think that in an upgrade firmware we could have the temp/hygro sensor included in the console ?
when testing the unit quite a time ago I could not receive any indoor temp data from it.
Do you have other programs there that report indoor temp? If so, please open ports 22 and 7777 of router and forward these to your Meteohub's LAN IP and give me access. please mail WAN IP to "info(at)meteohub.de"
