problem to connect meteohub
pasquaccino
Post by pasquaccino »
please help me.
i have an ip for meteohub that is 192.168.0.5...my router have an ip 192.168.0.1..with ipscan i found two host alive (192.168.0.5 and 192.168.0.1) but when i digit in the browser(firefox) 192.168.0.5 i can't open the meteohub's ip..i don't have open meteohub's server yet...why?
somebody can help me please.
thanks
evan.mac
Re:problem to connect meteohub
Post by evan.mac »
Try 192.168.1.77
If you connect then change to 192.168.0.5
Reboot
does the unit beep its IP by a long sequence of different tones. If so, the USB stick has been booted ok. If not, your USB stick has not been setup correctly.
Did you use the "physical disk" settings when building the stick with DiskImage?
