Meteohub 4.1 officially supports ebox-3300
What's hot...
I also added some info about ebox-3300 into the hardware menu section on the left.
Performance is between discontinued ebox-2300 and ebox-4300. Although being clocked at 1GHz floating point performance is a bit weak. As a result Meteohub recomputation is about two times as fast as NSLU2 but doesn't reach ebox-4300 or 500 MHz Geode levels.
Having a look at the price, the unit is very attractive (below $150).
During my tests I did not suffer any stability problems, but only time will tell this for sure. Up to now all x86 platforms perform rock solid. So when you have trouble with NSLU2 and/or USB sticks, you might think about a change.
