Hello, I've been happily running Meteohub on my NLUS2 for the past year. Today I decided to upgrade to 4.1a, and now none of my sensors show up. It seems to detect my WMR-200 because it shows up under weather stations on the USB port, but no sensors. I tried to down-rev back down to 3.3, but then the "weather data logging" service would not start and still no sensor data. I've since gone back to 4.1a, but I still have no sensor data. So right now my Meteohub is pretty much useless.
Any ideas? Thank you!
EDIT: When I reboot and click on sensor, the following error is shown:
error receive data from socket 127.0.0.1:5555: Connection reset by peer
Warning: Data logging has been halted.
Recent update to 4.1a and now no sensors with my WMR200
Re:Recent update to 4.1a and now no sensors with my WMR200
Are there no sensors at all listed on the "Sensors" page?bradb21 wrote:It seems to detect my WMR-200 because it shows up under weather stations on the USB port, but no sensors.
IIRC re-assigning the sensors found there is one of the first things to do when upgrading to v4
I've seen that.bradb21 wrote:EDIT: When I reboot and click on sensor, the following error is shown:
Sometimes it "solves itself" after a minute or so.
What I have usually done is to click (Data Logging Process) "Start" on the Maintanance page again and then it's been okay.
On the sensors page there are no sensors listed.
I've tried to stop and start the Data Logging Process several times, and I left it to run yesterday for about half a day with no change in results. I'm going to reformat my USB stick when I get home from work and redo the image from scratch with DD, and see if that helps. I will probably use the image for v3.3, and see if I can drop back to v3.3.
Please forgive me if this is a daft question...bradb21 wrote:It seems to detect my WMR-200 because it shows up under weather stations on the USB port
You say that the weather stations page show the WMR200 on the USB port - but have you used "Add a weather station" to actually set up the WMR200?
Yes I also added the weather station that was showing as available. Still not working.
This is the error I can't get passed even though it says the data logger is running I get this error
This is how my station is setup, and I've tried to click on "start" logging process on the maintenance screen several times.
Appears that maybe my USB storage device got fried. I tried to roll back to v3.1 and v3.3 with the same results. I also noticed some weird errors in the log pointing to my usb fob. I found another fob laying around the house, so I put the image on it (v3.3) and I now see one of me three sensors. I'm making progress, but still not back online.
What does Log Files => meteohub log show?
EDIT: I didn't see your last post (about the fried USB stick) before posting that question. Now you have made progress it is perhaps not relevant - but maybe it would give a clue to someone about your latest problems...
