Recent update to 4.1a and now no sensors with my WMR200
Posted: Tue Feb 17, 2009 12:30 am
by bradb21
Hello, I've been happily running Meteohub on my NLUS2 for the past year. Today I decided to upgrade to 4.1a, and now none of my sensors show up. It seems to detect my WMR-200 because it shows up under weather stations on the USB port, but no sensors. I tried to down-rev back down to 3.3, but then the "weather data logging" service would not start and still no sensor data. I've since gone back to 4.1a, but I still have no sensor data. So right now my Meteohub is pretty much useless.
Any ideas? Thank you!
EDIT: When I reboot and click on sensor, the following error is shown:
error receive data from socket 127.0.0.1:5555: Connection reset by peer
Warning: Data logging has been halted.
Re:Recent update to 4.1a and now no sensors with my WMR200
Posted: Tue Feb 17, 2009 3:24 pm
by skyewright
bradb21 wrote:It seems to detect my WMR-200 because it shows up under weather stations on the USB port, but no sensors.
Are there no sensors at all listed on the "Sensors" page?
IIRC re-assigning the sensors found there is one of the first things to do when upgrading to v4
bradb21 wrote:EDIT: When I reboot and click on sensor, the following error is shown:
I've seen that.
Sometimes it "solves itself" after a minute or so.
What I have usually done is to click (Data Logging Process) "Start" on the Maintanance page again and then it's been okay.
Posted: Tue Feb 17, 2009 9:02 pm
by bradb21
On the sensors page there are no sensors listed.
I've tried to stop and start the Data Logging Process several times, and I left it to run yesterday for about half a day with no change in results. I'm going to reformat my USB stick when I get home from work and redo the image from scratch with DD, and see if that helps. I will probably use the image for v3.3, and see if I can drop back to v3.3.
Posted: Tue Feb 17, 2009 11:56 pm
by skyewright
Please forgive me if this is a daft question...
You say that the weather stations page show the WMR200 on the USB port - but have you used "Add a weather station" to actually set up the WMR200?
Posted: Wed Feb 18, 2009 12:38 am
by bradb21
Yes I also added the weather station that was showing as available. Still not working.
This is the error I can't get passed even though it says the data logger is running I get this error
Posted: Wed Feb 18, 2009 12:39 am
by bradb21
This is how my station is setup, and I've tried to click on "start" logging process on the maintenance screen several times.
Posted: Wed Feb 18, 2009 3:25 am
by bradb21
Appears that maybe my USB storage device got fried. I tried to roll back to v3.1 and v3.3 with the same results. I also noticed some weird errors in the log pointing to my usb fob. I found another fob laying around the house, so I put the image on it (v3.3) and I now see one of me three sensors. I'm making progress, but still not back online.
Posted: Wed Feb 18, 2009 7:27 pm
by skyewright
What does Log Files => meteohub log show?
EDIT: I didn't see your last post (about the fried USB stick) before posting that question. Now you have made progress it is perhaps not relevant - but maybe it would give a clue to someone about your latest problems...
