Beeps
figgis
Beeps
Post by figgis »
Have been using NSLU2 for about 3 months with no problems. However on Sunday it started beeping for no reason the only way to stop it was a restart after which it was useless I can't access it via my browser. Anyone got any suggestions.
Re:Beeps
Post by skyewright »
figgis wrote:Have been using NSLU2 for about 3 months with no problems. However on Sunday it started beeping for no reason the only way to stop it was a restart after which it was useless I can't access it via my browser. Anyone got any suggestions.
This almost certainly indicates that the USB stick has failed. :(
figgis
Re:Beeps
Post by figgis »
Ok whats the solution? I can't talk to it via my browser so how am I going to configure a new usb stick. I'll buy a more expensive stick this time.
Chill
Re:Beeps
Post by Chill »
If you have done data and system backups you will not loose too much info :huh:
BTW, I would try Low Level formatting before buying a new USB. Some times when we say the USB is fried it just means bad data is the reason why it doesn't work properly. There is software (freeware) which is able to 'reborn' the stick.
Googling USB low level format freeware may give some light on it.
HTH,
Chill
