Graph uploads in version 4.1b
HeinrichH
Post by HeinrichH »
Just upgraded to version 4.1b. I want to add some more graphs to upload but after selecting a graph the screens blanks and does not come back anymore.
The system has already 75 uploads defined, is there a maximum of graphs to upload or so?
Checking the remote....
Re:Graph uploads in version 4.1b
That is pretty much. Could be a buffer overflow. Meteohub preserves up to 500KB for a web-page. Please save your "Graph Upload" page with your browser's "save page" function and have a look at the resulting file. How large is it?
HeinrichH
Post by HeinrichH »
I think thats the problem, the size is 494 kB (506.629 bytes) at the limit.
Is there a solution for?
I will give more storage for the next update and will limit it hard to 100 entries. Is 100 ok?
HeinrichH
Post by HeinrichH »
100 entries should be enough, a little bit shifting out with the defined graphics will do.
I use a lot of graphics to keep track of the indoor climate of my house in Portugal when we are away but I can combine some graphics.
Thanks for the answers and the work to do!
Henk
HeinrichH
Post by HeinrichH »
Now I have defined 85 uploads, page size is 536 KB / 548.864 bytes and the same problem occured when I add another upload,is 536 KB the limit?
The limit has been set to 900k and that should fit 100 entries as planned. Are you using latest version (4.2b)?
HeinrichH
Post by HeinrichH »
No, on the moment I'm using version 4.2a. The PC running MeteoHub is in my Portugal house and I'm working in England now. Tonight I'm gonna try to upgrade to the 4.2b version, the internet connection in the hotel is better than the connection on this location.
4.2a should be fine. I will try to simulate 100 uploads on my rig...
HeinrichH
Post by HeinrichH »
Tested something yet? I've still troubles with it. On the moment I can't change anything, after changing something or trying to delete a entry I will get a CRON error and the change is not saved
Do I have a chance to visit your system? I would need access on ports 22 and 7777.
HeinrichH
Post by HeinrichH »
Yes, no problem. I opened the requested ports, can I send you a private mail with the address and password?
yes, please send to "info(at)meteohub.de"
HeinrichH
Post by HeinrichH »
OK, I've send you a mail
bug found. will be fixed with 4.2d
