What's wrong with my rain?
A new day, a new question.
We have today a rainy day. And I watch on the screen from my WH1080, we have today 5,5mm rain. I watch on my Dashboard, it show my 5mm. I watch on my WD I have only 3,3mm. Where from the difference cam? I have switched the rain offset on WD, but I'm not sure is it right.
Thank you for help.
Regards Wöllkchen
Thank you for help.
Regards Wöllkchen
Re:What's wrong with my rain?
There should be no need for an offset in WD.Wölkchen wrote:Where from the difference cam? I have switched the rain offset on WD, but I'm not sure is it right.
When using the logging protocol, WD judges rainfall by spotting changes in the total rainfall in rain0 records received from Meteohub.
If you wish to study the Meteohub => WD data exchange look in
WD => View => WS2010-13/WS2500 data logger setup/info
It is hard to read that in the window, so what I do is
[RightClick][Select All]
[Ctrl][C]
Then paste the copied text into something else, e.g. Notepad.
Normally I'd use [Ctrl][A] for 'Select All', but that doesn't work in that window.
Sometimes you may need to try several times to get a good copy of the text.
Has your NSLU2 been doing a Recomputation? If so that may be the problem.
When Meteohub is doing a Recomputation on a NSLU2 it is so busy that it can't also respond to all the data requests that WD sends.
If this is the problem then after Recomputation is complete you may find that WD "catches up".
When the NSLU2 is doing a Recomputation it is probably a good idea to close WD, then restart it and catch up once the Recomputation is complete.
During a Recomputation, Meteohub on a NSLU2 can usually provide the "on the minute" summary of data, but may miss "every 3 seconds" requests. Unfortunately WD only checks for rainfall in the "every 3 seconds" requests. :(
Originally WD checked in "on the minute" too, but that resulted in duplication.
I have asked the WD developer if behaviour could be changed so that the more reliable "on the minute" data is used to judge rain instead of "every 3 seconds", but so far that change has not been made.
PS. So far as I'm aware it's only rain that is affected by this potential problem.
Hallo skyewright
Nice to hear you again. I shut wirte you the questions direct. Nice to now that you are here.;)
Hallo skyewright
That I found in Info from WS2010-13/WS2500 Datenlogger setup.
But what that want tell me?
Can you say it me? I can read in the 7. line rain0.........total=166.2
But I have never seen it on the display.
Wölkchen:dry:
Loaded all time records
loading the data file month22009.inf
Date /time (PC) that WD was last running is: 02/27/2009 20:51:00
converted to UTC Date /time that WD was last running is: 20090227195100
getting missed data initial 20090227195100 20090227195200
Decoding missed data
Decoding missed data, raw actual <logger>
<RAIN date=20090227195102 id=rain0 rate=0.0 total=166.2>
<TH date=20090227195102 id=th0 temp=7.0 hum=91 dew=5.6>
<THB date=20090227195102 id=thb0 temp=22.0 hum=47 dew=10.2 press=985.5 seapress=1014.9 fc=-1>
<WIND date=20090227195102 id=wind0 dir=225 gust=0.3 wind=0.0 chill=7.0>
<RAIN date=20090227195116 id=rain0 rate=0.0 total=166.2>
<TH date=20090227195116 id=th0 temp=7.0 hum=91 dew=5.6>
<THB date=20090227195116 id=thb0 temp=22.0 hum=47 dew=10.2 press=985.5 seapress=1014.9 fc=-1>
<WIND date=20090227195116 id=wind0 dir=225 gust=0.3 wind=0.0 chill=7.0>
<RAIN date=20090227195130 id=rain0 rate=0.0 total=166.2>
<TH date=20090227195130 id=th0 temp=7.0 hum=91 dew=5.6>
<THB date=20090227195130 id=thb0 temp=22.1 hum=47 dew=10.3 press=985.6 seapress=1015.0 fc=-1>
<WIND date=20090227195130 id=wind0 dir=180 gust=0.0 wind=0.0 chill=7.0>
</logger>
increase time 1
getting missed data 20090227195200 20090227195300
Finished*****
Decoding missed data, raw actual Error: Given start date "20090227195200" is newer than actual date "20090227195143" (all in UTC). Hint: Omit start and end date to get the very latest recording.
getting on the minute data 20090227195100 20090227195200
resetting the com port
getting on the minute data 20090227195200 20090227195300
getting on the minute data 20090227195300 20090227195400
getting on the minute data 20090227195400 20090227195500
getting on the minute data 20090227195500 20090227195600
getting on the minute data 20090227195600 20090227195700
getting on the minute data 20090227195700 20090227195800
getting on the minute data 20090227195800 20090227195900
getting on the minute data 20090227195900 20090227200000
getting on the minute data 20090227200000 20090227200100
getting on the minute data 20090227200100 20090227200200
getting on the minute data 20090227200200 20090227200300
Wölkchen:dry:
</logger>
increase time 1
Finished*****
There are other people too. Honest!Wölkchen wrote:Nice to hear you again.
You just happen to be asking questions about things I have some familiarity with. :)
The Forum is best.I shut wirte you the questions direct.
More people can answer (sometimes).
Many can read the answers, both now and in the future.
166.2 is the total of rain seen by sensor rain0.Wölkchen wrote: <RAIN date=20090227195102 id=rain0 rate=0.0 total=166.2>
When that figure increases WD should register rainfall.
e.g. if it became total=166.5, WD should see the extra 0.3mm of rain.
If that is all you are seeing, that that's strange.Wölkchen wrote: getting on the minute data 20090227195100 20090227195200
I just checked with v10.37N build 12, so unless Brian (the WD developer) has very recently reduced the level of feedback I'd expect to see a lot more than that. If that is all you are seeing, it may indicate a communication problem of some sort (though a network problem would usually result in some sort of error message).
I'd expect the 'live' phase of data collection to follow this sort of pattern, i.e. "increase time, then a block of data for a whole minute, then individual "latest sensor" every 5 seconds, then increase time and repeat the loop...
One thing to check would be that the clocks on your Meteohub and on the WD computer are both well synchronised.increase time 1
getting missed data 20090106094600 20090106094700
<TH date=20090106094601 id=th1 temp=4.8 hum=98 dew=4.5>
<WIND date=20090106094603 id=wind1 dir=225 gust=4.6 wind=5.4 chill=1.9>
<WIND date=20090106094608 id=wind0 dir=216 gust=6.7 wind=6.3 chill=1.0>
<WIND date=20090106094617 id=wind1 dir=248 gust=4.7 wind=4.6 chill=1.8>
<TH date=20090106094618 id=th6 temp=7.7 hum=77 dew=3.9>
<TH date=20090106094619 id=th0 temp=5.4 hum=88 dew=3.6>
<WIND date=20090106094622 id=wind0 dir=208 gust=5.1 wind=6.1 chill=1.8>
<RAIN date=20090106094624 id=rain0 rate=1.2 total=1190.0>
<T date=20090106094625 id=t8 temp=5.2>
<T date=20090106094627 id=t7 temp=3.0>
<TH date=20090106094627 id=th3 temp=10.1 hum=89 dew=8.4>
<RAIN date=20090106094628 id=rain1 rate=0.8 total=1263.6>
<WIND date=20090106094631 id=wind1 dir=202 gust=3.6 wind=4.6 chill=2.6>
<THB date=20090106094632 id=thb0 temp=16.1 hum=65 dew=9.5 press=1011.2 seapress=1023.0 fc=0>
<TH date=20090106094635 id=th5 temp=4.6 hum=98 dew=4.3>
<WIND date=20090106094636 id=wind0 dir=206 gust=5.5 wind=6.1 chill=1.6>
<T date=20090106094641 id=t9 temp=14.8>
<TH date=20090106094643 id=th1 temp=4.8 hum=98 dew=4.5>
<WIND date=20090106094645 id=wind1 dir=248 gust=2.7 wind=4.6 chill=3.2>
<WIND date=20090106094650 id=wind0 dir=222 gust=7.8 wind=6.1 chill=0.7>
<TH date=20090106094656 id=th0 temp=5.4 hum=88 dew=3.6>
<WIND date=20090106094659 id=wind1 dir=202 gust=7.3 wind=4.6 chill=0.9>
</logger>
yes extra temp 1 5
yes extra hum 1
yes dir
yes gust
yes wind
yes extra temp 6 8
yes extra hum 6
yes outdoor temp
yes outdoor hum
yes dir
yes gust
yes wind
yes total rain
temp=5.2>
*******temp only extra sensor found 8
yes extra temp 8 5
temp=3.0>
*******temp only extra sensor found 7
yes extra temp 7 3
yes extra temp 3 10
yes extra hum 3
yes indoor temp
yes indoor hum
yes baro
yes extra temp 5 5
yes extra hum 5
yes dir
yes gust
yes wind
temp=14.8>
*******temp only extra sensor found 9
yes extra temp 9 15
yes extra temp 1 5
yes extra hum 1
yes dir
yes gust
yes wind
yes outdoor temp
yes outdoor hum
increase time 2
getting missed data 20090106094700 20090106094800
Hallo skyewright
After the start today, the rain wars right. It look that WD doesn’t show me the rain of the day. But on the next day the rain is right.
Yes that's all what I can see. That's an authentic copy from WD.
That with the question direct to you, was a joke.
Of course, here is the best place for the question!
Greeting
Wölkchen
Greeting
Wölkchen
Strange.Wölkchen wrote:After the start today, the rain wars right. It look that WD doesn’t show me the rain of the day. But on the next day the rain is right.
Maybe I have something extra turned on that makes the extra detail show?Yes that's all what I can see. That's an authentic copy from WD.
If so, it was so long ago I've forgotten where it was set.
As you will have seen, WD has many setting, in many places!
:laugh: :)That with the question direct to you, was a joke.
I'm not sure if it is relevant, but that's not something I'm used to seeing.Wölkchen wrote: resetting the com port
I just searched a very big file of debug data (around 10 days worth) and the text "com port" was not found.
What do you have set in Control Panel => COM port => Release comport?
The only thing I have set is a tick in the box next to "Do not check for time to release com port".
Yes,WD has many setting.
Thank you for help!
I hope, if I have a question, I find your help again.
Wölkchen;)
Thank you for help!
Wölkchen;)
Hallo skyewright
In my Comport Panel is a tick on ; Comport relase do not consider.
"Do not check for time to release com port" that box I haven't.
But I have a box for : " Put back the Comport every hour." But haven't a tick on it.
You mean that's make touble?
Wölkchen
Wölkchen
Sounds equivalent. Perhaps a translation?Wölkchen wrote:In my Comport Panel is a tick on ; Comport relase do not consider.
Same hereBut I have a box for : " Put back the Comport every hour." But haven't a tick on it.
Probably not, since it seems that your settings are the same.You mean that's make touble?
I'm just trying to spot possible differences. So far we don't seem to have found one. :S
Hey skyewright
I have not a translation, but a Word-Dokument with a Screenshot from the Com Port setting.
You can download it her:
http://www.file-upload.net/download-149 ... t.doc.html
I delete on the 02.03.09 in the evening.
I think thats the safe way. Pictures says more then words.
Wölkchen
Wölkchen
That looks fine.Wölkchen wrote:You can download it her
Maybe the rain things was just a once only problem?
i.e. see if if happens again?
