Push Services
cbhiii
Push Services
Post by cbhiii »
I'm trying to configure 'push' on my Meteohub using Yahoo Mail and it is not working.
This web page says that I need to use SSL and port 465. I have the address formatted as shown in the image, but it still doesn't work. Is it becuase there is no SSL turned on?
cbhiii
Re:Push Services
Post by cbhiii »
Thanks. Image
Re:Push Services
Meteohub is not able to connect via ssl.
Some threads in the web indicate that the non-ssl ports for yahoo are also working. so port 25 for smtp is expected to be work.
try... host: smtp.mail.yahoo.com:25
and give a fully qualified source address (your yahoo mail-address for example).
cbhiii
Re:Push Services
Post by cbhiii »
I tried a variety of ways and different services to get this working by not using SSL.
Is SSL something that could be added in a future release? A lot of services are requiring it now.
Chill
Re:Push Services
Post by Chill »
In my opinion there is a bug in SetUp Push Services.
I realized when you change ftp configuration and you click either Save&Test or Save buttons the changes are saved but they're not effective. It keeps in memory former configuration...
I think the only way it works is Rebooting, but should it be really necessary to do it?
Chill
cbhiii
Re:Push Services
Post by cbhiii »
I too have seen where I change the FTP directory that it doesn't take effect until I reboot or turn on and off the FTP service.
