DEUTSCH:
Update V4.1d (NSLU2 und x86) enthält die folgenden Änderungen:
* Berichtigt die Meldung der Windgeschwindigkeit an das Wetternetzwerk Wetterspiegel.
* Zeigt bei Temp und Temp/Hygro Sensoren in Verbindung mit RFXCOM auf der Seite "Sensoren" bei "#" neben der Hardware-ID auch die am Sensor eingestellte Kanalnummer an (hinter dem Doppelpunkt).
* Schnittstelle zum Wetternetzwerk "Wetterpool" aktualisiert.
* Temp/Hygro Sensor der Konsole der RMS-300 wird unter Kanal 9 eingebunden.
* Datalogger beendet sich nun ohne "segmentation fault".
ENGLISH:
Update to Meteohub V4.1d (NSLU2 and x86) brings these features:
* Fixes wind speed reported to weather network "Wetterspiegel".
* Displays channel selected at a temp or temp/hygro sensor when in RFXCOM mode on "sensors" page. in Column "#" you will find the unique hardware id followed by the selected channel (separated by a colon).
* Interface to weather network "wetterpool" has been updated.
* Indoor sensor (temp/hygro) of RMS-300 console is recognized as channel 9
* Data logger does now terminate without throwing a segmentation fault.
Meteohub Update 4.1d
Re:Meteohub Update 4.1d
I'm still learning with my Alix 3d2 - but updated today from c to d and lost communications and access to my Alix - IP Scan showed it with the correct IP - but for some reason the auto reboot after upgrade didn't work...cycling the power did get it to work though.... Is that normal?
With ALIX 1D, v4.1c => 4.1d rebooted just fine.AAMFlyer wrote:but for some reason the auto reboot after upgrade didn't work...cycling the power did get it to work though.... Is that normal?
You do seem to be having a tough time with your 3D2. :(
Thanks! Yep - so far my 3D2 seems to be okay as long as I don't make any changes... When I make or apply a change - the LAN connections drops off and in the process of setting it up I think I had to cycle the power on my Alix and my router 20 times.
Not sure if it's software or if it's the Alix - but I lose that connection and an unable to access the meteohub even though I may be able to see it as available on an IP scan....cycling power seems to fix it though.... When I went to version 4.1d - it seemed to reboot and even flashed the LED's etc....but I couldn't access it until cycled the power... Maybe Boris has seen the same thing..?
And of course the 3D2 doesn't have a monitor connection, so you can't "watch" it boot to see where it sticks. :(AAMFlyer wrote:When I make or apply a change - the LAN connections drops off and in the process of setting it up I think I had to cycle the power on my Alix and my router 20 times.
I wonder if Log Files => System Log would give any clues about how far the failed boots got?
Maybe there is a pattern there?
AAMflyer, could you please grant me access to your Meteohub? That all sounds strange, I would like to have a look myself.
I don't have a probem with that - but that's a technical weakness of mine and not sure how to do that... I'll email/PM you so that you have my email address and perhaps you can walk me through it....I'm somewhat behind two firewalls with an ActionTec DSL modem and then a Linksys router then the meteohub.....
