Install problems on laptop
dcspicer
Post by dcspicer »
I downloaded and install debian according to instructions. The only problem that I had was that I could not boot using a usb stick, so I burn the image to a cd. Everything has been installed now I'm trying to install the setup.tgz file that I download from meteohub download section. I'm currently log in and when I type mount /dev/sda /mnt - I get an error, I guess, stating that you must specify the filesystem type. I do not know anything about linux at all. So what does this mean?
When I plug my usb stick into the computer it has the setup.tgz on it here is what it stats.
[ 1310.561339] sd 5:0:0:0: [sdb] Assuming drive cache: write through [1310.576318] sd 5:0:0:0: [sdb] Assuming drive cache: write through
I'm going to assume that since I copied the setup.tgz from my windows computer that this is going to be the problem.
Please help me with this. Thanks
dcspicer
Re:Install problems on laptop
Post by dcspicer »
Nevermind I finally got my problem figured out. Hopefully everything else works OK for me
hnoor0011
Re: Install problems on laptop
Post by hnoor0011 »
NOOR
