I need to add a serial port to my eBox-3300. I originally ordered mine without these ports.
I opened my unit and I see where the connections need to be made on the motherboard, but I don't know what the proper pin-out should be.
I know the pin-out of a DB-9 connector, but I'm not sure about the pin holes on the mobo.
The pin holes look like this:
    noooo
    ooooo
I assume that the pin hole that looks square (shown in RED) is pin 1, but I don't know if pin 2 is below it or to the right of it.
Does anyone know this pin-out or be willing to take a look at their own for my benefit?
Thanks for any help!
							eBox-3300 Adding Serial Port - Need Assistance ** solved **
Re:eBox-3300 Adding Serial Port - Need Assistance
I found it on the motherboard.
13579
24680
I'm worried that since I didn't order the serial port version of the eBox-3330, I wonder it there will be chips missing on the motherboard as well instead of just the DB-9 connector.
Does anyone know?
							13579
24680
Does anyone know?
I soldered the connector in place and it doesn't seem to work. Either I got the pin-out wrong or the motherboard is missing a chip that I need on it.
Any suggestions?
							Any suggestions?
On the underside of the mother board - are there a couple empty square plug-in's....?  I just fried an E-box 4300 accidently (put 12.5v into it - big dumb mistake!!!!) and have to buy a new one now - I have the two serial ports on the 4300 that were just plugged in on the underneath side of the motherboard...wondering if it's similar...
Gregg
						Gregg
Sorry to hear about your 4300. :( that's bad news.
Unfortunately I found out that my 3300 mobo doesn't have the serial controller chips installed so it was a waste of time for me to try and solder the RS232 connectors. Oh well, I guess I'll have to stick with a USB/serial adapter cable for my Vantage Pro.
