Though the site seems valid, the browser was unable to establish a connection.
When I used DiskImage on my USB stick (OCZ Rally2 4GB), I did not see Physical Disk as an option. I attached what I do see. Could this be the problem?
wdg
For night time cloud I use the temp difference between my main outdoor temp and a "temp in a jar" sensor. The temp in a jar was originally set up for daytime solar, but with small refinements of design it also acts as an 'black body' at night.d_l wrote:It's just a very semi-quantitative estimate of night time cloudiness and it only works when there is little or no wind. Wind causes turbulance that roils up the near ground temperature stratification.
Do you have some way to convert that temperature difference into a degree of "cloudiness" measurement within the Meteohub?The temp in a jar was originally set up for daytime solar, but with small refinements of design it also acts as an 'black body' at night.
In fully overcast night time conditions the two temps are the same. In fully clear conditions the jar is 1.4 C cooler.
The system is quite sensitive and works well. :cheer:
Not in Meteohub, but I do in Weather Display (which I feed with data collected by Meteohub). :cheer:d_l wrote: Do you have some way to convert that temperature difference into a degree of "cloudiness" measurement within the Meteohub?
PS. Though it is possible to use Meteohub's maths functions to display the raw temp difference, e.g.skyewright wrote:Not in Meteohub,
